- Passin_ThruExplorerA guy in Manassas VA repaired ours. Rivets were worn, one broke in 2.
- Blaster_ManExplorerA Flexsteel recliner and foot rest came with my coach. It was very uncomfortable and arm rests were so low they were useless. I sold it on Craig's list and bought a different model.
- MountainAir05Explorer IIOn mine at home, looks to be the same in RV, the rivet was broken between the brackets and that allowed the bracket just enough movement to let the level to slip by. When I push the back of the seat back everything went back in place. It took some moving around to find it.
I had to remove the metal frame from chair and put on work bench and I finally saw what it was doing. No way to get a picture from the underside without unbolting frame.
Also my chairs are early 2005 so not sure if they change the frame. There are no adjustments on mine at all, just solid connections with bolts and rivets. - pee-pawExplorerMountainAire05,
I have looked at everything but that doesn't mean nothing can be done. I'm no chair engineer. I have LazyBoys at the house that have 2 wing nuts to adjust for this but Flexsteel tells me there are no adjustments on their chairs. I am hoping someone on the forum has figured out a fix. - MountainAir05Explorer IIhave you look at the cam that the handle is attach too.
