ron_dittmer
Jul 20, 2015Explorer III
Dragonfly wrote:As I had practiced with our old 12V batteries here, when staying put for many days in a camp ground, I plan to do the same with 6Vs by running my generator to power up my 4/10/20/40 amp Black & Decker charger. It reduces charging time by a lot. Maybe this is hard on 12V batteries but pampering the batteries is not my higher priority.
HOWEVER, apparently many chargers through the converter are unable to charge the AGM's to their full potential. I am still researching this but, it looks like I will have to add a different charger capable of shoving that extra power that AGMs have, into them.
Also, your alternator may (or may not) be up to the task. A long drive will fully charge my AGMs but it takes a while. There are things you can do to boost the output of the alternator to get a full charge quicker but again, I am still researching that.
Bottom line ... to get your money's worth out of AGMs, research whether you might need a more powerful charger for the more powerful AGM batteries and, whether your alternator output is up to the task.
I welcome an education on this and will pass on what I learn as I proceed.
About higher output alternators, our 2007 Ford-V10 has an OEM 115amp alternator. On Ebay there are aftermarket companies offering direct bolt-in brand new replacements with near double the amp output, at what I feel is priced affordably.
