harold1946
Jul 22, 2015Explorer
EsoxLucius wrote:harold1946 wrote:Say what? My batteries accept 14.7 volts for bulk and absorption charging, and 13.7 volts in float. Such generalizations do no one any good.
It is best not to charge any battery to more than 13.8 volts unless de-sulfating or de-stratifying.
Its not a generalization, its a fact.
Read more carefully. Paul asked if his 13.6 volt charger would work and the answer is yes. That indicates to me he has a single stage charger, maximum output 13.6 volts.
If you do not believe fully charging a battery at 14.7 does any harm, give it a try.
Float charge is bringing them to a fully charged state. If 14.7 volts is used for float charging you risk thermal runaway on AGMs. Excessive gassing off of wet cells and total destruction of gel.
