Pirate1
Nov 10, 2015Explorer
Floor Scales
Found a place that sells a "kit" for building your own floor scale. My kit can handle 20K. The kit has all the guts you need, I need to provide my own platform. They recommend 3/4 or 1" aluminum. ...
wolfe10 wrote:dons2346 wrote:
This is totally wrong. Tires on the same axle should be set to the weight of the heaviest side.
Absolutely correct. All tires on an axle are pressurized based on the heavier wheel position on that axle.
But not sure this thread is about facts as much as it is about opinions.
