Pirate1
Nov 10, 2015Explorer
Floor Scales
Found a place that sells a "kit" for building your own floor scale. My kit can handle 20K. The kit has all the guts you need, I need to provide my own platform. They recommend 3/4 or 1" aluminum. ...
dons2346 wrote:
" At full weight your tires require 100 psi. So 1 side is 600lbs heavier. That's a difference of 3.5%. So what do you do? One set of tires(side) get's 101.75lbs and the other side get's 98.25lbs. "
This is totally wrong. Tires on the same axle should be set to the weight of the heaviest side.
