rtz777
Jun 22, 2022Explorer
Floor Wax - ZEP
About 8 years ago I coated my 02 Bounder with Zep floor wax and have since reapplied every couple of years. This year it needs to be all removed due to flaking. I am using ZEP floor stripper and its r...
rgatijnet1 wrote:
You can have a body shop TRY color sanding and see if they can remove the top \"yellow\" layer of paint and get down to the original white color. This is all assuming that the paint is thick enough to allow color sanding without going through to the body panel primer. Keep in mind that this was a floor wax and there is no telling what damage it may have done to the original paint. A body shop should be able to try a small area to see if it the paint is salvageable.
