bobphoenix wrote:
surf bum wrote:
Looks great! How did you do the edge boarders and the door step? I'm getting ready to install pergo, trying to get an idea what other people are doing.
Haven't done the front yet... (still carpet... and the step s already non-skid rubber...
The edging is the original, I was careful about pulling up the old corner bead... As for putting it back... I sleaned all the old nail holes and I used a brad nailer from Harbour Freight... ($29.99 with long finish nails. short brads and staples included...)
But, I think I'm going to replace the all the OEM with a better grade of corner mold when I do the Dinette...
Surf Bum,
I looked at Pergo today when I went to get more vinyl plank... it's really thick stuff... (about tree times thicker than any type of vinyl flooring...
Normally that's not much of a problem until you try to transition into spaces where you are not going to replace the flooring in... then you'll be faced with a pretty big transition...
The Pergo is nearly a full 3/8 inch thick and the vinyl products are only 3/16 inches...
