wolfe10
May 08, 2017Explorer
Yes, there are two different change intervals recommended by Allison depending on what fluid is used.
ABSOLUTELY, verify:
1. The fluid used is OK for the transmission.
2. Whether the fluid used qualifies for the extended service interval suggested for Transynd (or its equivalent).
For Allison 3000 series, I always use the Allison filter pack (PN depends on sump depth-- that are two different ones) and a 5 gallon pail of Transynd. Change takes 19 quarts, no that leaves you one quart left over. Just pour old fluid into the pail and take in for recycling.
ABSOLUTELY, verify:
38,782 PostsLatest Activity: Sep 10, 2026
