IAMICHABOD
Feb 09, 2021Explorer III
I have a 2006 Class C on an Express Chassis also.All the information so far has been good. I have a complete service record on my RV,it was a Former Rental. and the service you have in mind is a good one. My transmission fluid was changed at the 100000 mile service per the service manual.
I will add that 2 other things should be added to that list.If it has not been done you should change out your brake fluid. This was done on mine and also replaced rubber brake lines,front and rear.After 15 years they may deteriorate,mine were found to be in failing shape,they looked good on the outside but were bad inside,besides that are not expensive and a brake failure could be very expensive.
If you have a very good mechanic I would go over all these things with him,I did with mine at the 100000 mile service and I also changed out all the belts.
As for that pesky check engine light,my service records show that one 02 sensor was changed at 55000 miles and shortly after my 100000 mile service at about 103000 it happened again.
Good luck with all the services.
