rk911 wrote:
generally, yes. every now and then we run into an older FJ that has gas only in those lanes but it is really rare. you may run into a FJ here and there that has aux fuel pumps on one side of the lane. if you do and your filler tube is on that side here's how to use them.
- each pump will have a number. at the regular pump swipe your loyalty card (if you have one) and your payment card or pre-pay inside. when you're told to 'start fueling' lift the nozzle out of the holder and set it on the ground.
- at the corresponding auxiliary pump (it'll have the same number as the regular pump) on the other side lift the nozzle, engage the pump by lifting the handle and dispense your fuel.
- when done, replace the nozzle in the aux pump and then the regular pump.
we still see this setup but it's getting pretty rare.
So thats how those work. I tried to use one, but couldn't figure it out, so just left and went to truck lanes.
Now I know,.. Thanks
Mike
