If you shop and compare prices of different brands with the cost of Michelins and the FMCA program you can find other brands for less cost. BUT BE CAREFUL. You also need to compare capacity of the tires. I priced Hankook tires to replace my 275/70R 22.5 Michelins and found the Hankooks not rated the same as the Michelins. Two different tire dealers told me no problem just air them up to 130 pounds for the weight of my coach. I believe that is about 10 pounds over the max for the wheels. I have new Michelins thru the FMCA advantage program. When you do replace them have the dealer put on solid valve extenders on the rear duals and the stabilizers for them where they go thru the outside dual. You will be glad you did.
