noteven
Sep 16, 2015Explorer III
rgatijnet1 wrote:goufgators wrote:
On the Goodyear chart, under some psi columns, the weight number will be in bold print followed by a letter in parenthesis i.e. 4080(F).
Can someone explain to me the reason for the bold numbers?
Thanks,
On the Goodyear chart the bold means that for the "F" rated tire, 4080 pounds is the heaviest weight that tire can handle. As you go to the right, you will find the heaviest weight that the "G" rated tire can handle.
(Same rim diameter and dimensions tire available in 2 different load ratings)
38,763 PostsLatest Activity: Dec 05, 2025
