RLS7201
Aug 20, 2021Explorer II
I had the same vibration in my 95 F53. Some of the ring gear bearing shims had fell out and the ring gear and carrier assemble was moving around, causing a vibration. Luckily I found it before the ring and pinion gears failed. I'm still scratching my head as to why the vibration only occurred when the torque converter clutch locked up. Go figure?
Richard
Richard
38,782 PostsLatest Activity: Sep 02, 2026
