- ArchHoaglandExplorerJeepers92....If you had your RV life to live over again at what time/mileage intervals would you replace your belts and hoses?
I do mine about every 4 to 5 years and have been told that's excessive. - Jeepers92ExplorerIt was the ford as I stated. It was traveling friends. Called Good Sams and first call ended up worthless. Called on Monday and finally got a service call out to repair it. Costs over $600. I think the guy took a nap under the motorhome. I think I could have changed it in 15 min max if I could have gotten the belt. Thanks for the one answer I recieved for my question. I should have stated my problem in a clearer manner.
- PursuitInsightExplorerThe ...8110... is right, 8 ribs and 110 inch in lenght. If i remember well, the F53 is like the F550 or F650.
- PastorCharlieExplorerThe same fits multiply brands of vehicles
- MrWizardModeratorSignature says Dodge
Post says Ford
Which one is it - Chum_leeExplorer
John Wayne wrote:
On mine it's Ford XC3E-8620-AB (Motorcraft JK81107A) Dayco 5081103
Yes. No secret here. Most Ford Dealers will have it in stock. Very common item. Make sure you know the year.
Chum lee - John_WayneExplorer IIOn mine it's Ford XC3E-8620-AB (Motorcraft JK81107A) Dayco 5081103
- xctravelerExplorerCall Dodge Tech support - or any Dodge Service department with your VIN. They should be able to get the correct part number for you. Here are two numbers I found no idea if they are 24/7 or workdays only.
Dodge (800-423-6343) 800-4ADodge
RAM (866-726-4636) 866-RAM-INFO
For future, buy 2! keep a spare. We have a fresh spare with us at all times. Cheap insurance - Freightliner recommends that for their chassis. - 1492Moderator
38,782 PostsLatest Activity: Sep 10, 2026
