jamesa403
Aug 18, 2013Explorer
Something else other than the transmission could be water in your fuel filter. The symptoms that you mention are similar. If you added a couple of bottles of gas line antifreeze to the gas tank, and let it run for a few minutes, this will remove any water in the fuel filter, (water won't go through the fuel filter without being broken down by the antifreeze), and you should be fine. This is a cheap fix for the first thing to try. With a MH this age, and if the fuel filter hasn't been changed, this could be the problem.
