irvsproblems's avatar
irvsproblems
Ford E450 support
We own a 2008 Ford E450 chassis Phoenix Cruiser. On the way home from a weekend outing in the middle of May the Check Engine light came on. The next business day we dropped it off at Sunset Ford here in Saint Louis. They promised to check it out and call us with the diagnosis the next day.
“A defective PCM is the problem.” They continued “this is the engine’s main computer.Continued running of the engine could cause major damage to the engine and exhaust components. The part is on order and should be received by the end of May.”
As it got close to end of May, we received a call and a message that the part is still on order and will be received by the end of June.
At the end of June, you guessed it. “The part is still on order but Ford promised it will be delivered by July twenty fifth.”
Monday, July twelfth another telephone contact and the date of delivery was changed to September fourteenth.
We have asked about the possibility of finding a replacement in a salvage yard. We have asked about the possibility of repairing it. The answer we have received from Ford, Sunset Ford and Phoenix is “No.Each PCM is unique and built specifically for the engine.”
The people at Phoenix, Sunset Ford and those I have been able to talk to at Ford have all been courteous and sympathetic but unable to rectify the problem.
The wife and I are retired and normally travel during the summer. Ford has destroyed 2015.
I strongly suggest to anyone that is considering purchasing a new or used Ford powered RV, THINK TWICE.
  • Sounds awfully fishy. A bad PCM should result in a no-run condition. This is not a Ford problem. This is most certainly a dealer problem. Have you tried escalating the problem to Ford's motorhome help line?
