carringb
Jun 18, 2014Explorer
I'm kinda with Fred.... Considering the symptoms started after a bump in the road, a problem internal to the distributor could cause this. You symptoms fit a distributor that has gone retarded. I mean that in the literal definition of the word. It sounds like spark is no longer advancing.
I am assuming they have plugged in live shop computer to verify the signals from each of the necessary sensors? Has a cylinder balance test been done? Has the A/F ratio be verified?
At this point, it sounds like the shop is just throwing parts at it, and some of the parts changed should not affect drivability like you describe.
38,780 PostsLatest Activity: Jul 04, 2015
