Rocket9k's avatar
Rocket9k
Ford F53 460 powered fan clutch options?
Hello all, new to the forums. I have a 1997 Winnebago 34' on the ford F53 chassis. I would like to replace my fan clutch as I believe the original is getting weak.
Has anyone found a suitable replacement for the discontinued fan clutch for the 1992-97 460 powered F53? The original ford part, Part number F2TZ-8A616-B is discontinued and superseded by AU2Z-8A616-P, which is a truck clutch and will not work properly in a motorhome. My original clutch works but I believe it has become weak; It will not engage at highway speeds until the temperature has nearly reached the redline.
I tried the Hayden severe duty 2799 which some guys have recommended, but on a hot day it runs nearly constantly, and over cools the system to the point where the thermostat is closing, not to mention the noise was unbearable. Anyone found anything that works properly in this application? This is the last little hurtle I have with my RV and I can finally stop working on it and enjoy it! Thanks everyone.
