Effy
Mar 09, 2014Explorer II
wolfe10 wrote:
Probably more similarities than differences in terms of performance and handling between your W chassis and the post 2005 Ford F53. Both very good gas chassis.
As with any leaf spring suspension, ride and handling are quite dependent on actual weight vs spring capacity. Said another way, a short, light coach will likely ride rougher since the springs do not deflect as much (if the same GAWR) as heavier coaches on the same suspension.
Well said, Having a 16k# coach on a 24k# chassis I have very little unspring weight. The result is harsh feedback. You need some weight to compress the springs and soften the ride.
