carringb
Feb 20, 2014Explorer
MWOwner wrote:
Speaking of adding 12v outlets in the dash. Where would be the best place to tap into 12v under dash? Preferably, switched.
If you pull the dash panel, the dash support already has a hole in it to the right of the radio. I presume this was added included for a possible 12v outlet because there is already power there. I did not check it it was switched or not.
Also attached to the steering column support is a rectangle plug. This is the "Modified Vehicle Power" tap it. You can get the pigtail from Ford, and both switched and un-switched power is available from this connector.
38,707 PostsLatest Activity: Jan 05, 2014
