Just to add fuel to this debate, the last I read said Ford is coming out with a new F-150 if 2015. That's been the 'crown jewel' of the Ford line for decades in terms of sales volume; they don't make fundamental changes in that design without giving it a lot of thought. The cab will be made of _aluminum_ instead of steel, for a reported overall weight savings of 750 lbs. It's unclear to me if that's just the cab weight, or includes other components that are lighter because they have to carry less weight.
If this works out, the changeover to AL on other of their high-volume vehicles can't be far behind. I wonder how long it'll be for the Transit?
My limited understanding of aluminum sheet metal says that you must redesign the stamping dies entirely. It has more 'springback' that steel, so requires more 'over-bending'. This implies a new generation of design, since you're unlikely go to that _huge_ expense just to change material. It also requires more energy to weld, since it transmits heat faster. Of course, they could probably use adhesive bonding for a lot of the joints.
I'm wondering if the current Transit will be relatively short-lived, in the face of this. At a wild guess, a high-top long van might see a weight savings of 1500 lbs or more if changed to AL. That'd toss the fox in amongst the chickens.... ;)
Jim, "Mo' coffee!"
