timmac
Oct 14, 2018Explorer
Will Ford pay for their mistake or am I stuck with this repair, found this on another site, my chassis is a 2007.
TSB
06-21-15 MIL ON - DTC P1285 / P1299 - 5.4L 3V / 6.8L 3V - FALSE OVERHEAT
Publication Date: October 13, 2006
FORD: 2005-2007 F-53 Motorhome Chassis, F-Super Duty
ISSUE:
Some 2005-2007 F-Super Duty and F-53 Motorhome chassis vehicles equipped with a 5.4L or 6.8L 3-valve engine may exhibit an engine temperature gauge indicating an overheating condition with the malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P1285 and P1299.
ACTION:
Performing normal engine cooling system diagnostics in Workshop Manual, Section 303-03, if it is determined that the engine is not physically overheating (coolant expulsion), install a new thermostat and crossover pipe. They have been revised for improved cooling system flow characteristics.
PART NUMBER PART NAME
7L3Z-8575-A Thermostat - 5.4L
7C3Z-8575-A Thermostat - 6.8L
3L3Z-8C368-A Crossover Pipe - 5.4L
3L3Z-8C368-B Crossover Pipe - 6.8L
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
Note: Normal would be from 190 to about 220. The actual boiling point of the system is about 262. 212 water+5 for coolant +15x3 for cap pressure =262.
http://www.irv2.com/forums/f23/false-overheat-tsb-50007.html
TSB
ISSUE:
ACTION:
WARRANTY STATUS:
