DrewE
Apr 24, 2019Explorer III
steved28 wrote:Gjac wrote:
The greater advantage to buying a MH 2006 or newer chassis is the increase of HP and 3 valve engine (362 HP).
Are you sure of this? I don't think my 08' had a 3 valve engine in my class C. I have it now in my 2019 class A. Noticeable difference, especially mated to a 6 spd. tranny.
Your class C doesn't have the three valve engine because it's built on the E series chassis rather than the F53 chassis that a class A is built on. The E series chassis never got the three valve engine due to space limitations in the chassis (the three valve heads are apparently larger than the two valve ones). Even the current 2019 production uses two valve heads on the V10.
38,782 PostsLatest Activity: Sep 10, 2026
