haste_maker
Nov 23, 2022Explorer II
Ford V10
Has anyone had to replace the throttle body on a V10? And if so what year was your unit & the amount of miles..
haste maker wrote:That means your chassis is probably a 2006. Is there an engine code that shows up like a PO505, PO506 or another code that indicates an idle issue? You say it only idles, if you step on the gas will it stall?dodge guy wrote:
What year is your coach? Drive by wire started around 06?
2007 year
Gjac wrote:haste maker wrote:That means your chassis is probably a 2006. Is there an engine code that shows up like a PO505, PO506 or another code that indicates an idle issue? You say it only idles, if you step on the gas will it stall?dodge guy wrote:
2007 year
