dougrainer
May 16, 2021Nomad
You purchased in Texas. To use lemon Law you will have to lemon Law in Texas. Send a Certified letter to Ford/RV Dealer/FR detailing your problem. Cruise Control does qualify under lemon Law. Most OEM's do NOT want to have to defend Texas lemon Law cases. They usually lose. The main gist of Texas lemon Law is, SAME complaint/malfunction 3 times and 3 or more attempts to fix the SAME problem, the OEM is on the hook. When you sue Texas Lemon Law, the Chassis(Ford) the RV maker(FR) and the Dealership(probably the largest Motorhome dealer in the USA since you stated Alvarado) are all listed as the defendants. You do NOT want to go lemon Law if you want to keep the motorhome and attempt to get the CC fixed. It can be a LONG drawn out process and IF you use the Motorhome, it diminishes your case. Certified Letters usually do the trick. Doug
