pommyg's avatar
pommyg
Forest River Sunseeker E450 2300 MPG
Hi
I am looking for my first RV. I am considering purchasing a FR Sunseeker 2300 with an E450.
One thing bothered me about what was reported to me by the sales staff - mileage. According to them, the mpg on the E450 is better than the E350 which makes no sense to me. They reported an average of 12 mpg on their E450s - they are a rental company so must have lots of data. They dont have the reportedly more fuel efficient Chevys.
I found out today at the showroom that a Canadian gallon is an imperial measure (https://en.wikipedia.org/wiki/Gallon) and is about 4.6 liters v the US gallon which is about 3.8 liters. Just to make things more complicated there would appear to be an extra 20% in the Canadian gallon... Will this make a difference to the tank size? I doubt it and felt that this was irrelevant.
Even with this discrepancy, the average mpg reported that I have seen for an E450 is 8. With an extra 20% this comes to 9.6.
Have any FR Sunseeker owners with the E450 chassis reached an mpg of 10-12? I might travel once per year from Vancouver to LA and back or similar trip so it could make quite a difference in the long term and therefore to my decision. Apart from anything else, as a newbie, I am aware of appearing gullible to sales folk and want to know if I was listening to absolute BS or good honest sales patter.
Thanks v much
Pommy
  • Having had both an E350 (25' MH) and E450 (28' MH), my experience is that the E450 gets slightly better mileage because (despite the difference in axle ratio) the E450 doesn't shift down as frequently while driving. I believe that's because the E450 engine is higher into the torque range and is able to negotiate hills better.
    Usually avoiding Interstates and running 50 to 55 MPH, my mileage before towing was a shade less than 10. Towing the Focus it's slightly over 9.
    In the Rockies and WV, the mileage is dismal.
  • For what it's worth, I average about 10 mpg in our E450 Sunseeker
    2300. I do not drive with a lead foot, usually do about 60
    on freeways . So far most of our travels have been in Texas , which is
    pretty flat. Good luck with your new m/h.
  • Don't waste your efforts on trying to figure out a Canadian Imperial gallon....there is no such thing anymore....you will either be calculating fuel burn as "miles per US gallon", or "iitres per hundred kilometres"...all tank sizes are now shown in US gallons & litres...
  • I would be very happy with 10 MPG in a class C. However if you really wanted to drive 55 MPH, then 11 MPG might be possible.
    I don't know why a E-350 would get worse mileage than a E-450 built to have a heavier weight, and also a higher number rear axle ratio (typically) because the design engineers wanted the E-450 to run at a higher engine RPM for each given road speed, than on a E-350. The engineers predict that the E-350 will have a lower GCVWR, and thus can run at a more efficient and slower engine RPM for a given road speed.
    Anyway if you are looking at a 23' or 24' long RV, it should be much lighter than a "Typical" 30' class C with a heavier slide out. This will assist in getting better MPG. But I don't think that 12 MPG is possible with a gas engine today. There is actually 10% or more alcohol in the fuel, and that prevents cars from getting the MPG that they might on pure gas.
    The best way to improve the MPG is to slow down. Setting the CC at 55 MPH will save a lot of gas compared to 65 MPG. Also buy a couple of tanks of 92 octane fuel. See if your MPG improves. If you are getting 10 with 87 octane, and 11 with 92 or 91 octane, then it is worth it to spend 5% more on the fuel to get 10% more mileage from each gallon. You will actually spend 5% less over a 1,000 mile trip by buying the higher octane fuel.
    Fred.
