Markiemark32
Jun 05, 2015Explorer
lanerd wrote:
Ok, thanks. Can you tell me where (which compartment) exactly? Telling me it's next to the in-house filter doesn't really help as this is not my mh and I'm not familiar with it. I assume it is the wet bay compartment? And when you say it is an in-line toggle valve...that confuses me. It doesn't have a handle?
Sorry for the confusion, I just need more specific info as I'm totally ignorant of this mh.
thanks
Ron
On mine, on the passenger side, is a smaller general storage compartment right behind the rear wheels (not the large garage one), inside this compartment the back wall is a hatch, removable panel, which accesses where the in-house water filter is (glass screw on canister, with a water filter in it). This is also where the water pump is located.
in-line toggle valve. = A lever (handle), that swings just to two positions, either open or closed, this lever (handle), is actually spliced right into the fresh water line (in-line).
This compartment
inside compartment (sorry blurry pic), panel just has a swing latch
in-house water-filter and water pump -Blue line fresh water drain
Close up of in-line valve (in closed position), swings down to open -drain fresh water.
Newer Sunseeker and a little smaller one, but may be similar due to hidden location.
Markiemark
38,782 PostsLatest Activity: Aug 31, 2026
