Old-Biscuit
Jun 05, 2015Explorer III
Markiemark32 wrote:lanerd wrote:
Also, one more tidbit. When she is hooked up to city water, it fills the tank and then forces water out of the water inlet for when boondocking. Is this normal? That's why I was looking for a valve that would switch from city water to tank water.
Ron
Something does not sound right.
When hooked up to city water (specific city water hook-up, separate from fresh water tank fill hook-up), it should not be filling the "Tank", should be just pressurizing the lines to faucets & toilets, to provide water to the unit.
Markiemark:C
When connected to city water couple ways for it to fill fresh water tank.
1) Most common--Water pump internal check valve NOT closing so city water pressure backflows thru pump. Rebuild pump OR for $10 install an in-line check valve on pump suction line.
2) Water works/utility/wet panel......fill valve leaking thru which goes to fresh water tank. Rebuild/replace valve
38,782 PostsLatest Activity: Aug 31, 2026
