Daveinet
Apr 22, 2014Explorer
TPMS is probably a really good way to compensate for the lack of 4 corner weight. As long as the tire pressure rises the same on either side (assuming a cloudy day), then your side to side weight is pretty close. You should probably make a note of the weather conditions and the tire pressures, that way you have a point of reference to work with. You stated you are headed to FL, so the tire pressure will rise. Also keep in mind that your tire pressure will rise with speed. You may hit places where you find yourself driving faster as a result of higher speed limits and light traffic.
38,769 PostsLatest Activity: Mar 31, 2026
