wolfe10
Jan 13, 2017Explorer
Noel wrote:
There is a power sharing feature when AC is turned on when generator is activated. Is this a possibility ?
Power sharing merely limits the amount of 120 VAC (whether from generator or shore power) that may be used by the inverter/charger for battery charging.
Most common use is when plugged in to 15 amp shore power, so you can have some power for other things. It slows the rate of charge, as it limits how much 120 VAC can be used for charging.
