mikemc53 wrote:
Going to be traveling in some cooler weather and at least one of the parks we are going to requires freeze free water hoses after November 1st. Has anyone had much experience with these or do you just use heat tape of some sort with a standard rv water hose?
The freeze free hose is pretty expensive so I was curious as to whether it is popular or not.
Thanks.
I had to change undies (Well not really) when I read the price on that hose.
I now have two summer and one winter hose which I'm no longer using.
(I will tell you how I do it in winter)
The winter hose.. I went to BIG LOTS and got a string of Rope Lights. these were NOT LED but the good old fashing incandascant. Each lithe is just a couple watts.
I got a couple rolls of "Fancy" Duct Tape (Zebra pattern currently used to be polka dots) and taped the rope light to the water hose.
A thermostatic outlet adapter turns 'em on long about 35 Degrees. Real cute when the hose lights up.
How I do it.
Fill the on board fresh tank ...Disconnect and drain the hose.
