Gjac
Nov 20, 2014Explorer III
I have a 18 year old Norcold 681 IM model and am not familiar with the Domectic but if it has the black plastic latch one on top for the freezer and one lower for the refer section. What I did on mine when it failed the dollar bill test is to removed the latch (2 screws) and removed about .060 of an in. from the backside with a grinding wheel, and re installed the latch, this effectively created a tighter seal where the dollar bill no longer pulled out easily, lowered the refer temps and reduced the ice buildup on the fins. I would only do this if it fails the dollar bill test because every time you open the door you will let humidity in and ice forms on the fins anyways.
38,766 PostsLatest Activity: Jan 10, 2026
