One problem with electric space heaters is that the wiring in many RV's is not really up to the challange.. The "Quick Box" or "Swift Box" type outlets just can not haul the freight.
I added special circuits for space heaters (I have 3.5 here in Seneca, SC at the moment, 3 1500 watt and one 750, all thermostat operated)
On your furnace. Depending on your location I might be able to help but there is not much that can go wrong with those.. If you know how they work fixing them is fairly easy. I have a boiler plate that may help>
This document was created while I was diagnosing MY furnace.. I am told I missed one possible issue... Sadly I forget if I updated the document or not and the issue Bad connections anywhere along the line can lower voltage
When the T-Stat calls for heat the control board starts the blower (1)
The blower blows closing the sail switch (2)
The control board then opens the gas valve (3) and begins sparking (4.1)
Gas Flows (5) And ignitets (4.2)
The flame heats the flame sensor (5)
The flame sensor sends .480 volts to the control board (6)
which then detects the .480 and continues operation (*)
When the T-stat says "Enough already" (RV is now warm)
The control board shuts off the gas flow (*)
and then turns off the blower after a cool down (*)
*: At nearly every step the control board is involved. IF IT IS BAD, things will not work.. I recommend replacement boards from Dinosaur boards.. When Mine went out the Dino board was less than half the price and when opened the box the quality of construction and workmanship, and then design was very clear to my trained eyes.
0: No propane or propane TURNED OFF.. (I mean check the obvious first, In the original of this document I assumed you'd done that but.. Well.. I did not so....
1: No 12 volt to furnace, blower motor shot
2: Low 12 volt, air ducts clogged, blower "obstructed" bad sail switch
3: Bad solenoid, Clogged Gas Jet
4: .1: Bad ignition circuit (high voltage) on control board. .2: Points too wide (Very common it seems)
5: These do not often fail but they can
5: Bad connection, NOTE:
5 and * Bad wire.
* applies to all steps by the way So does bad wire/connection.
