Licreek wrote:
Hello all, spending our first winter in our 36' Damon pusher. Our furnace is busted and I'm trying to heat with space heaters. The heater in the bedroom works great but I can't seem to warm the living and one super slide. I bought what I thought was a large space heater. It got down to 24 degrees last night and it was really COLD in here. Is there such a thing as a high output electric space heater? I know the max output for the heaters is 1500 watts but wondered if there is one that is more efficient? Which one puts out the largest volume of heat? Any suggestions? Thanks, Lee
Have you determined what is wrong with the furnace? I had a furnace that blew fuses when I tried to use it. Turned out to be dirt dauber nests on the squirrel cage fan. Removed them. Replaced the fuse. Turned on and all was good.
As someone else mentioned - outlets may not handle running 1500 watt heaters full time. Keep a watch on the outlets.
