pianotuna wrote:
Smallest cheap (expensive) heat is 1800 watts iirc. That means it can't be used on a 15 amp-shore power.
Sizes are 1,800, 3,750 and 5,000 watts
http://www.rvcomfortsystems.com/#
Very pricey and requires many hours to install. No fail over to the propane furnace.
Cheap Heat is one package, with different settings, there is now a add on unit that will auto switch from 30 amp 120 volt to 50 and 220 volt, thinking of getting as would save me a 20 amp breaker, and 20 minutes to change wiring.
The only time consuming part of my install was installing the gas/electric switch next to the t-stat, required locating a spot between the FW and Black tanks to bring the cable to the underbelly.
To me the auto switch over is a no big deal to me, get out of bed flick switch, get back in bed.
