They don't put any insulation in the nose of these things and so the cold air can blow through all the litle nooks and crannies up there. When I changed out the front tv, I put some of those insulation bats up against the front cap. It sure ain't pretty,but I don't have to look at it after I got the tv in and I guess it works. I sprayed the pink side pretty heavily with a contact cement and just stuck them up there. If I can get up the ambition and some help,I may just pull the covering off the front,momma's side of the dash, and do the same thing. I met a guy from Canada that pulled the whole thing apart and used that spray foam,very carefully and he says that he can go out in the middle of winter and still keep pretty warm. Said it only took him two weeks to do it by himself and it was a real bugger to get it all back right.
