pointrow's avatar
pointrow
Freightliner heat
New Fleetwood Providence on Freightliner chaise . I can't get enough heat down on my feet when driving in 30 degree temps. Got down and checked the diverter valve and it turns for each setting but I don't see any duct opening for the feet. That and there seems to be some cold air flowing in from the firewall but no visible openings.
Any ideas?
thanks
pointrow
  • I have the same problem on a 2005 Fleetwood 39S - slight cold air draft and not enough heat pointed down at my feet. I bought a "T" fitting to cut into the heater hose in order to point hot air directly down at my feet, but the fitting was the wrong diameter for the heater hose. I need to keep looking.
    If your MH home is like mine, in front of the gas peddle, there's a major 12VDC line coming in. I added an additional 6 place fuse block there. If I don't find the correct heater hose fitting, I'm going to install a very small 12VDC heater in front of my feet someplace to warm up that lower corner.
    Let me know if you come up with a solution.
    Bill
