down_home
Jan 18, 2017Explorer II
Mine is misplaced. Available from Freightliner.
It looks like large wrench which it is. Ours was made of a fiber reinforced polymer I think.
It holds the cap on. Reverse rotation on side right side I think. it indictes on the wrench.
Pliers or other tools tear up the center cap. Inside there is amount secured to opposing lug nuts I think. The end that holds the cap is a threaded bolt. I always put some anti seize on it so weather wont corrode, if it gets to it, just a trace will do.
I've only had them pulled off once since we bought it to replace rear tires.
The center caps are available from Freightliner, if yours is messed up from pliers etc. They are sort a high for such a small piece.
