They are not separate systems, just separate sources. The threaded city water 'source' connect to your interior water system between the pump (supplied by the gravity filled tank) and your fixtures, including the hot water system.
There is a check valve in the pump that should prevent the tank from filling. Also there is a check valve in the threaded city water connection to prevent water from coming out the side, when the pump and fresh water tank are used.
Either one can go bad, in your case it is probably the one in the pump.
Ken
