inverseParanoid's avatar
May 23, 2016
Fresh water tank leak? Need temp fix in the next 48 hours.
Just de-winterized yesterday and there is a very noticeable drip coming from the undercarriage, I'd estimate it at dripping 10-20 gallons a day. I turned the water pump off and ran all the lines, and the leak was still going just as fast 30 minutes later, so I think it's the tank itself leaking and not the lines.
When winterizing I pumped RV antifreeze thoughout the lines but merely empty the fresh water tank and left the drain valve open because people recommended not putting antifreeze in there and instead bypassing it by hooking up to the pump directly, so I guess it makes sense that there might have been some water left at the bottom that maybe froze and unfroze a bunch of times over the winter and ended up causing damage.
Some friends are picking it up Wednesday afternoon and taking it 5.5 hours away for 5 days. I'm pretty sure I can get the tank out this afternoon and my tentative plan is to use Marine Goop to seal the leak, wherever it is. (We never drink the RV water and we always tell people to drink bottled water instead when they use it without us.) I don't need to stop the leak completely (though that would be nice), but currently the leak is bad enough that you'd have to refill it everyday if your site doesn't have running water.
Does anyone have a better idea for how to quickly fix this, or see any errors in my logic?
Thanks,
Josh
  • Eterbond can be used. They have a video "how to" on their website.
    But--find the leak first!
  • As far as removing all the water from the tank, I park my rig on a side slope to the curb to get out much more water since my drain valve is located along the side of the tank near the bottom. I will then run my pump until it stops spitting water - only air. Then I will use the pink stuff.
    I would find the leak before assuming fixes.
  • DrewE's avatar
    DrewE
    Explorer III
    Before doing anything too crazy, I'd double-check that the low point drain valves and the tank drain valve are all fully closed and don't have some bit of grit or something stuck in them.
    I rather doubt that any slight bit of water remaining in the tank would cause it to crack or otherwise leak. There's plenty of room (horizontally and vertically) for expansion.
    If you leave the pump on with the taps all closed, does it cycle periodically? If it does, that's a good indication that the leak is in the pressure part of the system. If it doesn't cycle, then the leak/drip must be before the pump.
