wa8yxm
Jul 07, 2014Explorer III
Ok I will draw you a wiring diagram each "(S-XX) is nothing more than a screw or nail like rod that protrudes into the tank at the proper level, and /\/\/\/ is a resistor.
Panel-----(long wire)------(S-Full)--/\/\/\/----(S-3/4)---/\/\/\--(S-1/2)
It goes on through another resistor to the 1/4 sensor but I ran out of line.
These resistors are in a small epoxy box, often orange, and often wrapped in tape, stuck somewhere near the sensors (Behind a metal bar on mine).
Now. if the tank shows FULL when it is, in fact, FULL then goes to EMPTY this resistor array has failed. Should cost under 10 bucks.
IF the tank shows FULL and 3/4 but never 1/2 Same thing
IF it never shows FULL, then the line from the panel to the top sensor (Full) or to the array would be my suspect
Sometimes the wire from the panel runs to the FULL pin, sometimes to the array and then to the FULL pin but the FULL pin is always Direct connect to the panel so it makes a great diagnostic device. Note if your sensors only show 3rds,, You may edit 3/4 to 2/3 and so on leave off the "Additional" line.
There is also a "Ground" Sensor pin near the bottom of the tank, not connected to the array it has it's own line back to the panel.
Another test, Using a jumper connect this Ground" sensor to one of the higher sensors, Panel should report that level of water. (OR tank level whichever is higher)
38,768 PostsLatest Activity: Nov 21, 2015
