captpar's avatar
captpar
Fresh water tank won’t fill
New one on me. Went to fill fresh water tank this morning usually takes 20 minutes or so to fill (100 gal) was on a quarter tank when I started. Checked after 15 min No water was going into tank! Never happened before, I had changed water filter the day before.so I put old filter back on,still wouldn’t fill. Checked that I had good water pressure out of the hose. Checked and recheck switch position on tank fill. No water will flow into tank . Any ideas? No gravity fill on coach (07 sports coach elite) tomorrow will try to use the water pump and a 5 gallon of water via the winterizing port.
  • Do you have a pressure limiting valve or attachment? That could be plugged with debris.
    You could also try to put water in with your drain valve open and see if you are pressurizing any part of the water system. If nothing is being pressurized then you must have a blockage somewhere at the beginning from debris that came loose and has blocked the input.
