What is the quickest way to dump the fresh water tank? Is there an easy way or do i have to turn the water pump on and run the water through the taps? I have a 2002 Itasca Spirit 324V Thanks,
We had a 25' 2002 Shasta Sprite with the bed in the RR corner of the box. The drain valves were behind a small panel on the side of the bed support because the water tank was underneath the bed. I had to remove 4 screws & then there were 3 or 4 valves there to drain the tank & the water lines themselves.
