I have 2000 HR Endeavor. I would like to know how to sanitize my water tank. I heard you need to put a mix of water and bleach in the tank. How do you get it in the tank? I only have a hose hookup to...
The best way is to mix a solution of water and bleach in a jug, empty the hose as best as you can, pour into hose and reconnect to fitting. Now fill as normal. You may need to repeat this several times to get enough in. Do this until you can smell the bleach slightly when you run the tap. Run all taps and shower to fill all lines. Let stand in lines for a couple of hours. Run water and refill to reduce bleach content. Roughly that's it. Good luck.
