RayIN
Dec 01, 2023Explorer
Pressuring the pump with 90# of air pressure is beyond its design limits, which likely damaged the pump diaphragms and seals.
The usual cause of pump cycling is a water leak somewhere, and the reply suggesting the commode water valve leaking is valid. Have you check that out and eliminated as a possible source?
38,782 PostsLatest Activity: Sep 10, 2026
