enblethen
Oct 30, 2014Nomad
A check valve installed in the line. It can go either before or after the pump. Best is after as if you have a complete pump failure, you could still have city water.
Depending on make and model of pump, you could take pump apart and find the small amount of debris causing the back feed.
38,769 PostsLatest Activity: Apr 05, 2026
