Rice wrote:
John&Joey wrote:
There are ways to avoid some of it. One is using a 12V fan on the fins. Best for the short term RV'ers not so much for FT/PT'ers.
Why isn't a fan on the fins a good idea for fulltimers?
Because it doesn't solve the problem, it only delays it by a month or so. What will happen is where the fan is will be no frost, but the rest of the fins will be covered. Moving the fan only moves the spot of no frost. All the time the freezer will be building up frost which will need to be taken care of.
Think of it this way, if the solution was so easy don't you think Norcold would have done it already? A fan does circulate the cold temps around better and that was the real reason I used one.
