CA_Traveler
Mar 30, 2015Explorer III
rodjburge wrote:116V is not considered low by anyone. You have a bad board.
After unplugging from source power and operating on generator, it appears that the 116v is low enough to cause the fridge to glitch to "Lo AC". With the gen running I am getting the full 120v at the outlet and the fridge seems to run nominally.
Riddle solved....normal ops will need to be with fridge on LP as long as it is hot enough to require air.
Thanx again all
The US standard is 108V to 132V. You should not be getting a Lo AC error at 116V.
38,778 PostsLatest Activity: Jun 04, 2026
