late_bloomer's avatar
late_bloomer
fridge setting in 05 Dolphin
I am at work, DW is testing our Dolphin in the back yard. She told me the fridge (a dometic double door w/icemaker) wasn't working, and that it was prompting her to select a setting. The choices were AC, AU, and LP. I told her to pick LP and make sure the propane was turned on. Which setting is for shore power?
  • You should set in on AU - that is automatic meaning that if electricity is available, it will run on electricity. If there is none available, or the power goes out, it will automatically switch to propane. When power comes back on, it will automatically switch back to electric. This way as long as the frig is working properly, you don't have to worry about a power outage when away from the rig.
