CA_Traveler
Dec 26, 2021Explorer III
Don't assume a Freightliner shop has an knowledge about your RV, especially electrical. They should be familiar with OTR trucks but not necessarily a RV which has various modifications including chassis. Try another shop or mobile tech. Get wiring diagrams and equipment location information from your RV dealer or mfg. Talk to the shop mgr and make sure he understands your problem and conviences you they have someone that can locate the problem. Tell him what shop you went to that failed to find the problem and what they did.
BTW Replacing pressure switches sounds like parts swapping without any knowledge of the problem which is a common and sometimes expensive technique. Are you sure those switches were any good? What is the voltage on each side before during and after the brake petal is pushed? Did they leave the new switches in place since they didn't fix the probem?
38,782 PostsLatest Activity: Sep 18, 2026
